Second Thoughts...Which Axle do I Install the Locker??
Dante's Inferno, CA
Long story short...I have a Lokka (same as Aussie) rear locker unistalled. I also have an Eaton/Harrop E-locker that will fit either front or rear uninstalled. Original plan was to have the Harrop E-Locker installed in the front and the Lokka in the rear. I'm second guessing this application and considering having the Eaton/Harrop installed in the rear, selling the Lokka, and saving my pennies for another Harrop for the front.
Any sage advice out there from owners of selectable front and auto rear lockers?
IMHO your current planned setup will be the simplest and most reliable setup possible. Remember the Lokka will never have air line, actuator, electrical or any issues at all and being AWD you can't even tell it's there.
If you plan to do part time conversion then yes you want selectable.
This is a loaded question and opinion is what you will get. After having two ARB's in my current 80 and the elockers in another and an Detroit rear/ARB front in my last trailer queen, and lockrites in an FJ40 years ago, my preference is the twin ARB's. They are very strong and actuate instantly. Yes, I have dealt with a couple air leaks but those are usually the result of a faulty install.
If your 80 is mostly used offroad then your current plan of lokka rear/ Eaton front is great. If you drive on the street a lot then I would save for a second selectable locker.
If you are still AWD it would behoove you to put the selectable in the front. If you put the Aussie in the front then you'll have to deal with it 24/7.
Yeah...this is a good point. I guess my pause is that I don't have first hand experience with a rear auto locker. Seems like most people don't notice them, while there is a small minority that really don't care for them. I do plan on installing a Harrop in both axles at some point so I think there isn't much harm in trying an auto locker for a while. thanks for the replies.
They are different and I'm not sure how they'd fit the front AND the rear.
Yup. Different part numbers front to read. Do NOT appear to be interchangeable.
You can always try mine and see if you even notice the auto locker.
95% of the situation will only need rear locker. With the simplicity and reliability of auto locker means 95% of the time you don't have to worry about air line or electrical issues.
Is selectable better? Yes but I choose simplicity and reliability because I don't like to be under my rig middle of no where. Less moving parts the better. For front you have no choice but to go the selectable route.
I've done the auto locker thing a few times, great bang/$ mod, but I would never put one in the front diff.
Selectable front locker or no front locker are the only options I would consider. I would not put an auto locker or spool or anything else I cannot switch off in the front unless it was a trail-only vehicle.
Having done F/R ARBs and e-lockers a few times now, I would personally save up and do selectable front and rear. But I'm older and have a better paying job now :) You'll probably be happy with the lunchbox in the rear and selectable front too.
I always thought the front and rear diff carriers were different sizes since the ring gears are different??
Yes..you are correct. I somehow misread the fitment literature related to the locker. I guess that makes my decision MUCH easier! :doh:
