Second row seat removal
Lake Orion MI
Wanting to remove the second row seats to get at a spill underneath the carpet. Looks like I just have to remove the two bolts in front of each seat. is it that simple, or is there a trick to it? I noticed there are some pretty good sized springs in that front bracket.
Thanks, Eric
Not tricky at all. I forget the details of removal but there are a couple of bolts to undo. I think getting to them required removing a plastic cover which seemed like the trickiest part. There are the springs that rock/tilt the mounting bracket forward when undoing the bolts but it isn't a big deal. Just unscrew the bolts and you'll figure it out.
2 bolts on the front and 2 on the back when you flip it up
x2
If you have a spill that bad, I'd take out all the carpet and pressure wash it. Of course this involves taking out the front seats and replacing the carpet jute. Incredibly easy and cost effective.
4OE1augDPUhO9AyMhNIBBowRqTsH8wT2FpAnmf8FmWzzIUFIbUQu78Mxh6l_HRbI0LqXZtAR3IjnI6hYBCTGW53nhouAiZnLaKH_upnGJY3WGM4hmRm_Yy9FyoEJahvLd3KyoghOq-V55qfb3Rzsp5GlXcyTEcCiUohY_vma8N2rfTqK8YMQHFRV8KL8llFKugtLJMX2DlNVfAgcYIleYRKHKASdTHNKrrILRt-ebnzFwzkM8OuzKOjPuD8x0tRqn9ettTfyk4fC0j8P1iW5wgEO-5MeBP4LsZVsGyI4uCVCIddbhF4d3jMthqKqnq1ElUD8XevPJkgGFAUmUlLchenFjyFSDfnffJcSJzOuZY6j67Fk4OGqP1W3FI36xUeDaAaWuDYyfPOiw81rerYoEtkAPjkudbBXm6XDs98ZdPDrj6Fo8b3wx5PEmQ0ATY5_SbqU5U8ktbldNLwA6SjDVHrpp-M9hQOrGyZw3uuI1oewyHtpTiJUYKiUSX4l17WFamRaFVn4fAcEx3Dsq71HRJguB-qsYV8UHKDFYj4QIxTs9DRLocWy-TJkRkJd_DvbsBU3goGSvRI62J47EQRhkpLg7u5tI74Sb1P50q3usC9HPprh=w534-h711-no
JW_EQwmOJTKO4VJ7DNT5ReaiOPxJmwO0vnNgHdOBrFSHRLgKoQ4GHYjbBOfSn1vY56BgDymi-lBgGwxxwzrgsicr3XfvIa-A7GY026EVj9CXQTN4liDOQhw7Cn-n6idTUe64lR52IDvMpuh48fDqTtLez8lVF531EiVBdY2G0pbeizBHUzQ6UJzh5pabW1PRCHloh3oMjYdGfCYvSSoBFYb_AnkxZTzoV_0vCrB-IVaZrKqayCTulut6rISCEp_6b0hvVXvv7BRKzjGCVpoNKdzHMTLYhtajSyZsmIhr_2MyqQ78kK2brQBYTz_RMr8ytCDm_bqPuUNBlR4jb5Afqau1qXiGW7wvTC72PGuA3kX5CXzCP5oBFimx-9S9jkkD0NdzrAUS5Za_8LxYbtgEZaIOB10Kf90GDjG9oQ0mlwNHmqoaSnt4tz9As_k1IM4zBJmhyNMzF0vqc6FVlzi_PqnAhv2UlpHGLF_oTe-DRMzm-I6X6UE1AAsS0vXEkNMoGs0slKhvfjoR2ENSu9TojQfehtg733CWEqJ-6HHl60dC4nqdBP0-Fcxbv36GmGDnc8xipmdONyyHUi1O2E8MJWOZNX9iNLwV1l8KDot84IGdxGK-=w534-h711-no
Im looking at the back seats when they are folded up and i don't see two bolts...i see the long metal rod that comes down and fastens to a bracket on the floor ...looks like I need a snap ring plier to remove that arm. Is that what needs to be removed?
Taking out the carpet is actually a great idea as I need to take out the front seats to repair the front to back gears for the power seats anyway.
Other than the front seats, I would assume the center storage compartment needs to come out(looks like 3 bolts) and is there anything I need to do with the shift console.
For assembly, would there be any benefit to putting a Dynamat like material or just the jute that you mention? Im guessing the Dynamat would alter the carpet in how it lays back down.
No snap ring pliers needed. There are 4 bolts per seat for the front seat and the second row seats. The third row can either fold up against the window or you slide them forward on the rails and lift them out. With an impact wrench, a ratchet, a 6" extension, you can have all the seats out in less than 20 minutes. Another 20 and you can have the carpet out.
Remove the 4 snap on plastic covers that cover the 4 mounting bolts that bolt each seat to the floor pan. Use a 14mm socket and remove the 4 bolts per seat.
Takes all of 5 minutes per seat.
You're overthinking a very simple task.
