seats - what to do?
Atlanta
I'm trying to figure out whether it makes more sense to repair or replace my seats. I've read all the threads on refinishing with leatherique, leather mender, etc...and it looks like some have had good results. However, I've got a good size tear and two seams coming undone (one is bad), and that is apparently a much more difficult thing to address (as I understand it, you have to remove the seat covers to re-sew them...and that sounds awful). i found a guy who will fix the seams at $150 a seat, and do the refinishing job for about the same, but then I'm looking at $600 in total. Alternately, I could get some Corbeau Moabs for about the same price. Plus, I could prob sell my current seats for something, making that the cheaper approach. Buying new skins (like those from AATLAS1X) is cost prohibitive i think (i'd prob pay someone to do the install).
I'm rambling. Sorry. Looking for advice...what would you do? I've read alot about how many folks think the stock seats are lousy and hard on the back, etc. While i personally haven't had much issue, maybe replacing them is the way to go?
I'll attach a couple pics to help in your assessment :)
Thanks....
Mike
As someone who had the same problem once, let me shed some light:
Corbeau Moabs
Pros:
Cheap
Available mounting brackets make installation easy
Comfortable...initially
Cons:
Cheap
Mounting brackets are kinda pricey and need to be modified for the PS to clear the rear heater
Are not heavily padded like OEM and made my butt and back sore after awhile YMMW
No lumbar support
Feel cheap compared to OEM
Don't sit at the right height - they are too low
Repairs/Covers = temporary fix
Shane (AATLAS1X)
Pros:
Made the whole interior look new again
Front package includes seat leathers, arm rest cover and door panel inserts
If you purchase new foam, your seats will be better than new and way comfortable!
Cons:
None really
Not only is your old leather shot (judging by your pictures) your foam is likely gone too. If you simply fix the current leather, your seats will not feel any better since the foam is old. Adding additional foam may help, but is only a temp fix from my experience.
You mentioned Shane's fix might be too much for your budget. Having done the other two options before I contacted Shane, I will tell you to save your money and do it right. Also, if you are over 6 foot tall, get a set of Landtank's seat brackets to get more legroom. Together these two fixes will make your 80 a pleasure to drive again.
another option- finding some grey cloth seats--bonuses:
-no power/electrical to fail.
-about 80lbs less weight
-extended legroom compared to leather if you are over 6'.
-cheap
-slightly more comfy than leather
-bolt in -less than 10min per side.
-OEM
-did i say cheap- car-parts.com or mud classifieds parting out
*can also spend balance of $$ on waterproof/grimeproof/washable covers and still be under the cost of other options.
gotmud -
That's disappointing to hear about the Moabs...it was your original post that made me think it was a good option! Did you install Shane's leather kit yourself? If so, how bad was it? (I've read someone else's post...didn't sound worth it). If you had someone else do it, how much did they charge?
Guess I'm looking for a total cost to go that route...including the replacement foam.
Thanks.
I was pretty satisfied at first with the Moabs as they were a huge improvement over my tattered OE seats. The honeymoon was soon over due to the seating position (too low in my opinion, and not adjustable) and the padding didn't seem to remain comfortable to me. Keep in mind, I am 6'1" and 230lbs. The seat back was a little narrow for me and the Moab's side bolsters felt like they were pressing in on my back. I also have a tall torso and still felt the seats were too low. The :princess: who is 5'7" and 130lbs said they fit her fine, but didn't offer enough padding and again, sat too low. IIRC, the PS had to be raised about an inch higher than the DS to clear the rear heater.
I have driven a TJ and a 4Runner; both had the Moabs. In either case the seat height was not a problem.
I did not install Shane's kit myself. I have a buddy who owns an upholstery shop and installed both seats. I plan to replace my middle row leather soon, and would probablly do them myself. Silicone spray, hog ring pliers and patience seem to be the three tools you'll need. Others may be able to give you a better idea on labor. IIRC, Romer has a thread from when he replaced his.
Not to jack your thread...but I have a quick question while the seat discussion is hot:
> I have a 92 with decent cloth seats, but am itching to convert to leather. Does Shane/AATLAS1X (who I assume is a forum member?) offer any options? I would imagine the foam is different between cloth and leather. Also, any idea on cost?
Not only is the foam different, IIRC the foam for a leather seat will not fit a cloth seat frame.
Do it right and get the kit from AATLAS1X its about 200 more than your going to spend on those old seats, they look like mine. Keep in mind you can't polish a turd! Get new foam too mine is hard and gives me a numb ass after 30 mins. AATLAS1X kit is on my "to do list"
Contact Shane (he is in PDX, FYI). I think he has an option for leather covers for cloth seats. He also has a thread or two in the "vendors section" which may shed light on this.
I scored Corbeau brown cloth Sport seats on ebay for $150, they were like new. We initially made some brackets (thanks fourtrax), I ended up buying the driver's side bracket from Corbeau.
On the driver's side, I used some poly swaybar bushings between the seat and the bracket to get them to the proper height. As noted the Corebau bracket sits the seat down too low. This also allowed me to tilt the bottom to my desired angle.
When I received the seats, one had been slightly broken in, the other was new. I put the new one on the driver's side. The thigh bolsters were a bit high and the seat firm.
After a couple of months now, this seat has broken in very VERY nicely and it is all-day comfortable.
The thigh bolsters now do a superb job of keeping me comfortable and in place. If you have a lot of junk in your trunk (aka fatass), they will likely squeeze you. The seatback is somewhat wide so the bolsters on it provide plenty of space to get comfortable.
On a couple of recent day trips of 4+ hours, I've found the seat so comfy that I don't squirm or move around any longer - which is a major factor in fatigue and irritability.
The only downsides are the shape of the seatback for the upper back, and the non-tilt headrests. For the lower back and lumbar, it is perfect for me, support is superb w/o being intrusive. However, my upper back is nowhere near the seat (same on the pass side), and the headrests don't tilt so they are useless.
BTW I am 6' and 215, wifey is 5' 8" (I am not allowed to post her weight lol), and we are both very very happy with this.
