Seatbelt mounting question
Abingdon, Va
I’ve gotten some seatbelts to put into the ME spec FJ55.
I’ve located the mounting points on the pillar for the retractor side, can’t quite figure out where the buckle side mounts
With some mercy to a newbie- where does this side mount-there are no mounting “holes”- floor or bench seat rear frame rail?
They are just under or maybe even slightly behind the back of the front seat. They are in the floor.
Here's the best photo I have of the front seatbelts. You might need to copy this photo elsewhere and zoom in. The seatbelts are all unbolted but the ends are still in the proximity of the bolt holes. Hopefully that gives you an idea.
Here are the rear seatbelts with the seat out. These are just behind the back of the backseat on the little vertical section of the body.
FWIW you might consider keeping all your questions in your main build thread. That way you have all the information in one place. Just a suggestion.
