Seat Fix
Near Junk
I am looking for the extension brackets that I've seen posted here to extend the DS seat frames to give you more leg-room. Someone makes and sells the kit. Tried searching here and no luck - I know its here.
Someone recall the company that sells these?
AndrewT
I have it installed in my rig and it's great. The brackets only take a few minutes to install and the leg room is fantastic. Best mod I've done as I enjoy driving the 40 a lot more with the added space.
Thx alot for the info. Thats the company that I remember.
AndrewT
I have some machined from billet aluminum I'll give you. They move the seat up approx 1.5" but not back. Let me know if this helps Beeker.
Just out of curiosity, why do you need to move the seat back? (I'm 6'4" and fit fine in my -40, but it has a 13" steering wheel the PO had put on.) Is it an issue with legs fitting under a stock steering wheel.
long legs
Not long ago I read a post here about moving the original brackets around and it worked great for me. I gained about 1.625 back and that made a world of difference. All you do is turn the two rear brackets around at the rear of the seat. This moves the mounting holes back on the front. You will have to drill a hole to match the hole in seat in mount nearest the council. Then the A frame bracket needs another hole and a small ear welded to the front of the bracket with another hole to match hole pattern. Nothing hurt and only extra holes in brackets and not through tub. Good luck. :beer:​
I am 6'0 and I am cramped in there at max adjustment with my legs grass-hoppering the steering wheel. I mounted the seat frames to the tub (new Aqualu) so I maybe could have done something wrong there but I knew this seat bracket extenders were out there and cheap ($35) so no big deal.
AndrewT
