Seat Adjustments
Mandeville, LA
When sitting in my 94 LC I feel like the seat is reclined to far back. When I have adult passengers sitting behind the driver and passanger seatsI would also like to have the seat more upright to allow for more knee room. I have the seat adjust to its most upright position but is still to " layed back " for me. Is it just me or is this a common problem. If so, is there a way to modify the seat to sit more upright ? :)
You might be able to add a washer or two on the rear mounts. But you might need longer bolts.
I'm only 5' 10". With shoes, say 5' 11". When I have my two kids sitting behind me there is not much room for them to sqeeze in. Then my youngest is still in an infant rear facing seat and there is no room between his seat and the back of the drivers seat. If only I could adjust the seat a few inches to make the back support closer to a 90 degree angle.
I tried a few washers under each of the rear seat mounts. Worked perfectly. I placed three washers under each side. Bolts are plenty long enough. Much more comfortable (for me) now.
Leather or cloth seats?
When I first got mine I thought the seat didn't go back far enough and was going to buy Land Tanks seat extender. But after a couple weeks of driving it I found that I actually wanted the seat up-right and forward a little. Give yourself a couple weeks to get used to it and you may find the seat has enough range for you. But the washer solution is a cheap as free fix it sounds like.
