I have 2 pm-1's hooked up through a hellroaring unit. I also run a 150 amp alternator from a sequoia using photomans bracket. Outside temps here are 20-30 deg.F.
The main battery is 1.5 years old, the the backup is 1 year old. This is setup for one to be a true (backup) battery where there are no loads connected to it and all ways reads 13.2V at rest. The other pm-1 (main) has everything else connected to it, but no large loads (like a frig) after shutdown.
I have been watching the voltage of the main battery gradually decrease over the last year. It used to be about 12.8-13V at rest and now when i check it before starting it reads 12.2V I was fine with it being a little lower but 12.2 on a AGM is like 50% discharged (possibly less) from what I have read.
Today it finally gave up the ghost, turned the key and the dash lights just dimmed. Hit the switch to combine and it started right up. I checked the ground and other connections and I know it could also be my starter contacts or NSS connector. I'm starting with the battery because its easier and also under warranty.
The charge voltage is 14.4 at startup and drops to 14-13.8 while driving during the day. If driving at night with the lights it stays about 14.2V I attribute this to the alternator/regulator keeping up with the current draw. It also rises when using the power windows.
I'm going to sears tomorrow to swap out the main battery for a new one, Its close and then i only have to pull it out once (hopefully
Questions:
Has anyone ever had a problem returning batteries at sears? Does it matter that I was using it in a car and not a boat or RV?
Does anyone else run a pm-1 and monitor the voltage regularly? What kind of voltage readings do you get with the car off or on? Thanks for any input
Questions:
Thanks for the input but also THANK YOU FOR YOUR SERVICE
I dont know how many times they said its not supposed to be used for a starting battery, my response was that it was an off road vehicle that wasnt driven alot (half true)
Ended up walking out with a new battery.
Seems the "backup" which was moved to the "main" location has now failed as well. Since the new battery is still sitting in the back of the truck it's hard to say for sure that its not something else. She made it to her friends house fine but a few hours later when she went to leave, the truck would not start. Got a jump and let it run for a bit, turned it off to make sure it would start again and nothing. Jumped it again and drove it home with a follow vehicle.
