SD40 Questions
Bainbridge Island, Washington
I was so lucky to find the original carb in one of the boxes that came with my friend's '67. Included were three Keyster rebuild kits, which seem to be unobtanium now, and so I dived in. All pretty simple and it's gone back together just fine, except for two things:
1- how do you measure the lifting rod/step-up rod adjustment. I see how you bend the throttle connecting link to adjust it, but don't have a factory 'carb adjust kit' which I assume had a little template. Anybody have the measurement?
2- That throttle connecting link slips out of the lifting rod hole (the top of the link). I wonder if cutting a groove and putting a clip on that end would work. Note how the lower part of it is worn away, which is probably not helping the link stay attached. I could also just make a new one if it's just because of the worn part.
The other thing I found was, like others have noted, the top of the air-horn indeed was warped inward, which would make the glass leak. Hopefully bending it straight as I did will give me some mileage from it.
Last question on this subject- what years air cleaners will work on this single barrel? I see a few of varied vintage on eBay. And is it easy to tell the difference between dry and oil? Prefer the dry.
Castings warping from heat (soak), and not really that much heat considering the setup. Not one of Aisin's best achievements. Nice fix!
Mark or Jim C would have answers you seek
Mark's off road
