scout power steering question
890man
Thousand Oaks, Ca.
I have done the searching and reading but there still seems to be a question about what pitman arm to use? I am using a scout box in a fj55 with the stock six and a s/r kit. It also looks like the 80 TRE's are the way to go. What pitman arms work with these and what are you guys using for this setup.
Thanks
Yea, I saw that on one of the writeups. How long is it? Is that have some drop to it? I dont want to get one that is too long and gets hard to control at high speeds. The same amount of turns of the steering wheel would be fine with me.
890; i did this swap recently, and used a gm truck tre brazed into a cut down draglink w/ stock scout pitman. ends up @~3 turns L-L. a little quick but if your alignment is good it works OK.
to answer your Q: a 1975 I6 camero has a 6.75in c-c pitman that is flat and fits both the scout box and a fj55 tre taper. this info is in the faq under scout steering conversions.
HTH, carl
Thanks, I have the scout pitman and it is long. I don't have a measurement but it looks like It would be a bit sensitive. I think I will look into the camero arm. I saw the writeup but just wanted to get some user feedback how they actually feel on the road.
I have one from an older Wagoneer or Cherokee, 81 or 82 I believe. If I would have known, I may have went with a later 80's model Cherokee pitman. They're shorter and have a bit of a drop. Be warned, therse mofo's are a b*tch to get off. I broke Napa's rental pitman arm puller trying to get one off. I ended up using one of those small propane torches, a puller, and a huge bar to pound on it from above. Be prepared.
I'm using one off of a GRAND wagoneer (gotta be better than a plain wagoneer)
Thanks guys. It looks like the late wagoneer is the way to go for me. :)
