I think so! Finally haha. I would agree though. It either worn weird or was mismatched. Knowing the small history on this cruiser...I think the later. Sounds like some OME original height or 2" lift would be good. just need to pick a weight. I suppose medium would be good?
IIRC, the OEM height OME coils are only available in one choice and I think they call it heavy? It designed to help the unlifted deal with the weight of a winch, etc. If you do revert to OEM height, you will want to check the steering caster in case it was corrected to suit the lift. Shock lengths might be longer on a a raised suspension but it's easy enough to puti some OEM Tokico shocks on them
If you stay with the lifted version, it should be matter of hooking it back together, assuming everything else was righ. Not sure you can do that with this truck
