The current software versions with XGauge are 3.14 and 3.15 you can check this from the home screen and pressing MORE>MORE>MORE<VERSION
Displaying Horsepower as a Gauge
You can have Horsepower read out on your ScanGauge as you drive.
* To start, from the HOME screen use MORE>MORE>MORE>XGAUGE
* Then in the top right select the number of the XGauge memory you want to use (0 to 24)
* Next <EDIT this will take you to the TXD screen
* Using the buttons next to + and - after each character the -> in the top right will move to the next character space.
* Enter 00 into the TXD screen and press OK> You will be taken to RXF
* Enter 400080000000 and press OK> you will be take to RXD
* Enter 0000 and press OK> you will be taken to MTH (math)
* Enter 000A00170000 and press OK> you will be taken to NAME
* You can enter whatever name you would like up to 3 characters, when you are finished press OK>
* Lastly press SAVE.
SC use informations from the ECU throught the ODBII protocol and plug .
The one describe by 1LoudLX, the plug used for emission test and error code read/reset
sweet. I called a vendor and he said if we can get a group buy together. about 5 people to buy some. he will let em go for 150 each. not bad considering that they are 170. and they are brand new. Hopefully I can put something together and get one for a good price. more people he said lower they go
where is the ODBII and ECU ports then? I looked today and could not find one. Can anyone snap a picture of it and post it?
