Hey guys, would like to get some feedback and start a discussion to help me make up my mind!
Background: Rebuilt '78 350 block. '78 heads. Weiand intake, carter AFB competition series carb. New comp cams EXTREME Energy 4x4 cam, with lifters, etc. Mallory HEI distributer with vacuum advance. Electric fuel pump. My goal is to be able to turn the key and go, whether it's for a cruise or hitting some rocks all day.
Options:
1) I have an older analog Holley Projection 4D partial kit given to me. It has the throttle body, the computer, hacked up harness. The throttle body appears to have only the TPS, and no other sensor (isn't there supposed to be an IAC?). So my understanding is I'd need the IAC, MAP sensor, Coolant Temp sensor; which only comes form Holley and I haven't priced this out yet. Seems like the general concensus is the 4di system (laptop programmable) is great, but my analog style is hit or miss.
2) I can get a 1990 350TBI out of a blazer for free, but the motor is bad so I'd only be taking off the TBI. Sounds like most if not all the sensors are there as well as the computer. Biggest headache I see is wiring, which would be just as much as a pain for the Holley kit since it's so butchered and missing everything. Not sure how available documentation is for it.
3) Rebuild the carb and pray it does what I want.
I'm currently replacing the entire fuel delievery system up to the carb, including the gas tank as it has rusted out a little bit. So I plan to have the new tank fitting with a return line before I put it in. I'd like to accomplish something reliable (offroad mostly) for under $300 with what I have.
I threw in a couple pics of the projection unit just incase something sticks out.
Thanks.
Options:
Thanks.
