Sandy the Troopy Build
Northern NSW
Hi There,
Newbie to the site so apologies if this is posted in the wrong area.
I have just recently aquired a clean FJ45 troop carrier (Sandy as thekids call her) and also a HJ61 12ht donor. I will be documenting the build as much as i can but the plan is to build a reliable tourer to travel round australia with my wife and our 4 kids to see our amazing backyard.
I would love to here any advice from people who have done the same conversion and build in particular with the hj61 vacuum transfer and the 40 chassis issues and also pwr steering. I am aware that there is some amazing info one here which im in the process of going through.
Heres some pics
Nice! :beer:
Congrats on your new troopy acquisition, it's a nice one and love the color!
I look forward to the transformation.
BTW ~ Welcome to the MUD family!
Nice Troopy ! Welcome !
:cheers:
Update-
Started getting ready to take the 12ht out. Happy some coolant come out. Will be giving the 12ht and gearbox a freshen up once out. Next up pulling out the 2f.
Update - Both engines are now ready to be pulled out.
A few questions.
Are you able to change the big and bottom end bearings through the sump?
Also where in Aus can I buy the Ford F-250 shock towers and what year model are they from?
Are the hj47 engine mount the ones that I need in the fj45?
Also the 60 donor has LSD in the rear was thinking of putting it in the Troopy but it's wider does anyone know if the diff centres are the same and also whether the rear brakes with hand brake will work on the FJ45?
Cheers
Welcome to MUD :flipoff2: great to see another Aussie here on the site. However you are confusing me a bit. First couple of pics show Vic rego and then Qld rego but you say you are from northern NSW. I am probably guessing that somewhere around the Tweed and the rego is just eaiser up here in Qld. Look forward to watching the build.
Yep you got it! Easier for rego and mod plate for 12ht and seats in the back.
A few questions.
1. Are you able to change the big and bottom end bearings through the sump?
2. Also where in Aus can I buy the Ford F-250 shock towers and what year model are they from?
3. Are the hj47 engine mount the ones that I need in the fj45?
4. Also the 60 donor has LSD in the rear was thinking of putting it in the Troopy but it's wider does anyone know if the diff centres are the same and 5. also whether the rear brakes with hand brake will work on the FJ45?
Cheers
1. Don't know - but I assume if there's access then yes?
2. Gotta be a million places. Just google.
3. Yes.
4. The centres are the same so you can swap the 60 series LSD centre into the troopy diff housing. But they're not that great.
5. If you're running the H55 [5 speed] from the HJ61 then you'll need to run the handbrake on the rear diff to match - same as the HJ61 runs. There's a few ways you can do this: a] source a handbrake rear axle from something like a 5 speed BJ42 [rare] or a 5 speed FJ40/45 [also rare]; b] slot the HJ61 axles under the troopy [but you may run into width issues as they're 2" wider each side - I think]; c] convert your rear current troopy axle to handbrake type. How? I don't exactly know but I know it can be done.
Update-
Both engines out!
What's the differences between the FJ45 transfer case and the hj61 transfer case other than the vacuum H4 and drum hand brake? They look the same on first inspection. Can I make the HJ61 into manual transfer with parts of the FJ transfer?
