Sagiianw Pully Removal
Walnut Creek, CA
I need to replace my Power steering Punp. Ho do I get the pully off?
Is it Pressed on?
There is a allen type bolt in the end but I can not get it loose. Everything turns.
Any suggestions?
Dave
Of course that would be Saginaw. Hard to type with 3 year old trying draw next to you.
can you say press.
You may want to switch to a bolt on pulley style to simplify this process in the future. I do have an aluminum bolt on pulley that you could have. I will give you the napa # for the pump if you want PM me.
Hawkdriver's right
I'm with Hawkdriver. They charge you like $50.00 bucks to borrow it, you get it back, but you have to go back to the parts store.
JR
A puller isn't a bad investment if you work on your vehicle much, they can be used for a lot of things.
Rezarf <><
Like Rezarf said.
I just happened to snap a shot of the one I rented from Advance Auto Parts a whiles back. Something I need to invest in. Round $90 I think for this one if you bought it. Has quite a few different pullers in there.
Puller
Well I'm too late to tell you that you never - I mean NEVER use anything but a power steering pulley removal tool for a pressed on pulley. If it is a bolt on with a key to keep it from spinning, that is a different story. If you look at the front of the pulley that is pressed on you will see a flange that a power steering pulley puller fits around and is locked in place by a slip ring. You then use two wrenches to remove the pulley without any chance of distorting it. I believe you have already learned that a standard two or three arm puller is asking for the additional cost of a replacement pulley. I'm not sure what price you put on the aggravation. You can do a search and find any number of power steering pulley removal and installation kits on the web for a small investment. Most auto parts stores rent them for a small fee.
By the way, that pulley kit pictured above has some nice capabilities. It is, however, a waste of money for properly pulling a power steering pulley.
the attached picture is a power steering pulley removal and installation kit for GM pumps. Cost is $29.50 at mytoolstore.com, p/n 7847.
