Just finished my Safari Snorkel Install. I thought it was pretty easy. So here is my step by step....
1. Remove airbox and fender inlet from under hood. Lower or remove plastic under fender wheel well (I just lowered mine). Remove air duct and power antenna. I just cut the antenna wire instead of trying to fish it out.
-I chose to remove my antenna instead of trying to heat and bend the snorkel because with my aftermarket radio, I'm not using my antenna anyways.
Here is the airbag and fender inlet removed
Fender liner lowered and intake tube removed from inside the fender
These are the original parts that are removed and not to be used
2. Align the template and mark holes. The directions say to use the line the fender indicator light up with when slot in the temple Since mine doesn't have one, I just lined it up with the back and top of the fender. It worked fine.
I marked the holes with a sharpie then pulled it off
3. Start drilling. I drilled the 4 1/2 inch hole first so I could test fit the snorkel before drilling the rest. I got my hole saw from Lowe's for about $40. The instructions call for a 114mm which is the same as 4 1/4". I started with a small pilot hole first. About that time I asked myself "What in the world am I doing?"
