looks clean, my whole purpose is to get any type of fuel container OUT of the passenger compartment tho.
I noticed even with the tank inside the cab it took a few cranks to get fuel into the bowl. I was planning on putting a check valve before the mechanical pump to help keep the fuel filter full and reduce the pull from the rear of the tank...if that makes sense.Depending on how long it stays parked and whether the tank is above the fuel pump. If parked for a long time fuel in the carburetor could evaporate and if the tank is below the pump, it could take excessive cranking for it to suck fuel out of the tank. A small electric pump mounted near the tank could prevent this. Remember that the Weber only needs 2 - 3 lbs for fuel pressure, anything over and it will most likely run rich as fuel would be pushed into the engine.
