Had a guy named Brad out in Sooke fabricate my bumpers and sliders over the holidays.
Front bumper is very similar to the one I had on my 60, but with a few extras.
- LED pods inset on the angle as they are a 250 degree light radius which will give forward and side lighting.
- Jack-All lifting points cut on the lower angle plate which give easy safe lifting access and its right beside the tow hooks which help give the lift stability.
- Jack-All storage on top of front bumper.
- Front stinger and side corners allow me to see where the front and corners of the truck are, which was impossible before (70’s hood angles in and you can’t see the edge of the fenders).
- H4 24v 7” Aux lights.
Rear bumper is ridonkulous.
- Double heim joints attach each swing out to each rear door, allowing the swing out and the door to open/swing at the same time. I’ve never liked how swingouts are separate from the doors in that you have multiple things swaying in the wind when open. All’s I gotta do is open the door and the swing out just comes with it. Engineering where and how to mount the heim joints was, I’m sure, a real PITA! That’s why I gladly paid someone else to do it! There is a thread on Mud that I unashamedly stole this idea from.
- Spare tire holder pretty simple.
- Fuel can holder has a chainsaw mount and resting plate, and then an LED 250 degree flood (on its own switch as I didn’t want it to come on with reverse lights).
- Mini LED brake, reverse, and signal lights stacked in the same order as the OEM rear lights. Although the rear signal is mostly (but not entirely) blocked by the swing out spindle, I wanted to be safe and avoid a VI with an obstructed signal.
- Lift-All lift points cut into the bottom angle just like the front.
- Dual 2” with pintol hitch.
Sliders
- Double plated and welded to frame.
- Very simple and strong design.
This has allowed me to mount my 24v Aisin winch!
Still need to finish up some wiring for lights and winch though.
