Rusted & Broken Exhaust Bracket
Oregonian moved to Vegas
First trail run and I already broke something... Any suggestions on a cheap fix until I can save up the $$$ to do a fully new exhaust? It sure makes a lot of noise banging around down there...
weld it back up and maybe put a piece of metal to help support it. it will probably break again later though. most muffler shops shouldnt charge you more than 10 bucks to do that. i know i work for one.
The bracket is available new if you care to go in that direction.
17568-66010, list $46.90, mudder $35.17.
The rubber mount will almost certainly break when you attempt to take it apart. 17567-17010, list $16.18, mudder $12.13.
D-
I agree with CDAN if you're gonna change the mount the rubber piece will break apart when removing. When I replaced my rubber bushing the bolt just snapped when I was trying to remove the nuts.
D-
Three years ago I had the same problem. Brown Toyota in Charlottesville told me I'd have tp buy the whole exhaust section, the bracket alone was unavailable. :mad: This was before I found 'mud and Cruiser Dan. I had mine welded and it's holding up well after lots of wheeling.
I have two busted mounts. I'm gonna redo the whole exhaust from the headers back.
:meh:
:meh:
I did it for mine dude, so worth it. From the headers back was $500. Just make sure they put in the 02's! Screw the cats. ;D
I like the idea of gaining some HP and fuel efficiency by replacing the header on back but in Vegas I have to pass emissions... not sure about eliminating the cats.
I'll put a bandaid on the exhaust for now and keep working on base line stuff. It has 157k on the original HG so I'm bracing for that too.
Thanks for the advise guys.
You can buy a high flow cat if you truly want to open up your exhaust. I have nearly 200k on my HG.
Gotta pass emissions here, too. :doh:
What diameter of pipe did you run?
