- Thread starter
- #1
Get a grinder cut the rust out then customize the correct shaped steel plate then weld the new plate back in.
How much do you think the repair will cost?KC Colors does good, but expensive work. Tons of body shops in the area that you could check out. There's another called Evelynn Brothers that is also top notch from what I understand.
Hope you get it sorted out.
Not sure... I've never taken that kind of repair to anybody.How much do you think the repair will cost?
Why not lop it off and put a 4x4labs under there? Then nobody knows. Just make sure the frame isn't rotted through
