Someone w/ some experience give me the pros/cons of both. The rust bullet seems to need more prep/finish than the conversion product ?
I'd be fine using either POR-15 or RustBullet again. Most of the complaints I've heard about either are from improper prep.
K I guys I just registered so hello, I think the human verification/captcha where you have to type in the advertisement slogan is hilarious but onto my question...
I was thinking of using the folling and was wondering if it would work on top of one another:
1.) Get all the loose rust removed and use pre metal prep to cclean and degrease
2.) use rust converter to get rid of the rest of the rust
3.) use an etching prime
4. use a 2k aersol epoxy primer
5.) Use rust bullet
6.) Top coat with a rattle can or maybe some eastwood extreme chassis black
I dont know if I will use every step but are these all compatible with one another, I would probably only use one primer but I only want to do this once. I will be coating the frame of my 97 blazer 4x4 2 door. and can rust bullet be used on fiberglass is place of resin like por-15 thanks. And can rust bullet be used with epoxy primer or rust bullet. Thanks.
So I cant use a product with acid on any layer touching the epoxy primer? And they do make 2k epoxy primers you just pull a plug on the bottom of the can and shake and you have a few hours to use it...
Those 2K spray primers are expensive (~$20 a can).
I'm having good results with Chassis Saver Gloss Black on the bed of my FJ40. The prep isn't too difficult and it lays down really nice. I'm going to line over it with some tintable liner (grey).
One thing that I noticed so far is that Chassis Saver will lift/bubble any existing paint. I'm just going back and grinding the bubbles down and reapplying where it needs it.
