Rubbing....
San Juan Puerto Rico
Website
www.facebook.com
I upgraded from 33.12.50x15 to 35.12.50x15. I have 4.5 inch lift plus 1.5 inch Metaltech spacers and my tires are rubbing inside the fender well when the truck turns and the suspension compress. A different wheel solve this? Any ideas to solve this???
Go back to 8" wheels or pull out your 5 pound hammer & give that fender a little massage.;)
Another options is get under the fender with a 10mm socket loose the inner skirting & push it back a bit. I almost got .5" more room when I did that.
Same area rubbing turning left. Do people usually cut this part out or is there a cleaner way to go about it? Thanks.
Adjust the track bars (panhard). If you have the stock bars, you will need to buy adjustable units in order to relocate your axles laterally.
Solved the problem by changing to OEM wheels plus KO2s
If your tires don't rub, you can fit bigger tires.
It's good to rub it every once in a while.
Or small tires can be made to rub by using the wrong wheels. Excessive width/offset increases scrub radius, causes unnecessary interference. In this case, likely easiest to adjust the turn stops to prevent contact.
I upgraded from 33.12.50x15 to 35.12.50x15. I have 4.5 inch lift plus 1.5 inch Metaltech spacers and my tires are rubbing inside the fender well when the truck turns and the suspension compress. A different wheel solve this? Any ideas to solve this???View attachment 1165275 View attachment 1165276
If it ain't rubbin you need bigger tires. Sounds like yours are perfect.
