I was driving my car today, and when i parked it i could smell what seemed like rubber or maybe plastic burning, any ideas? i wasn't driving it rough at all.
I didn't do anything where the exhaust may have beeen pressed up, although i'll check that out anyways.After jamming up my exhaust I noticed that smell and it was where the exhaust was pressed up against the floor and was melting the coating under the carpet.
Did not rebuilt the front end yet, i plan on doing that after exams.Have you rebuilt the front end yet? Any leaks?
I had a seal go bad and the burning grease smelled a lot like burning rubber.
Have not lubed the drivelines, although i prolly should do that.Did the drive lines recently get lubed? Sometomes the grease wil get on the exhaust pipes and it stinks pretty bad.
Dave
It seemed to be coming from the passenger side more.what area did it seem to be coming from?
I get the smell of burning rubber simply from new tires when I park it in the garage. How new are your tires? For some wierd reason, it's more noticable on rainy days which is counter intuitive.
DougM
I've mentioned this before. Every now and then I'll get a whiff of rubber smell when I walk by the front of the truck on the PS. It was of some concern but I could never track it down.
That was until yesterday.
I did the oil pump gasket this week which required the front of the engine to get stripped down. When I was putting the thing back together I decided to install the water pump pulley that comes with the York kit.
Get the truck back together and start it up. There is a noticeable difference in the way the engine sounds. Before there was this bearing of sorts which wasn't very loud but still noticeable. It was the belts running on that old pulley. When the engine runs now all you here is the clicking of the injectors and valves. Unbelievably quiet, like a new engine! That had to be the rubber smell that I was smelling. The old pulley did look a little tattered and the belts were rubbing on it as they turned.
so i prolly need just a new pulley, not the york one. I guess its worth a shot.
