RTH please - battery is dead, stranded
Twentynine Palms, CA
I parked for a half hour with my lights on and now my truck wont start.
I have a dual battery system and it still wont start!
I put the IBS battery monitor into linked mode.
Both battery show 12.4v. When i link them and try to start they both go down to 12v.
I dont have anything hooked up to the aux battery
Is there something wrong with my battery monitor? First time ive had to use it like this.
POST EDIT:
Thanks to everyone for the replies. For anyone new stumbling through here having the same issues, I’ve recapped all the suggestions, knowledge and advice in the thread into a compact list below.
12.6v to 12.7v is good voltage for a charged battery.
11.9v minimum is required to start the truck.
If there’s power to dash lights when the key is turned to ‘On’
If you hear a ‘click’ when turning the key to start
And if the starter doesn’t crank at all
It’s most likely the starter contacts going bad. Tapping on the starter with a crowbar, breaker bar, hi-lift handle or hammer should jostle it loose and it should start after that. If it’s the starter, rebuild by replacing contacts or replace.
Second, check fusible links going to the battery. You can rule out bad wiring or fusible link by checking voltages at the starter with a multimeter.
Third, check ignition wire.
Fourth, try removing everything from the positive battery terminal, cleaning each one, and reattaching.
If it’s a battery issue:
Weak, slow crank
No lights on the dash
If main battery is dead and/or if battery management system has failed:
Use jumper cables to jump the aux to the main battery
Other notes:
When looking at the battery’s voltage through a battery monitoring system, multimeter or other voltage display, it’s normal to see a drop in voltage.
When using a dual battery setup, it’s normal to see both batteries at the same capacity when the batteries are linked together.
Check your fusible links. Sounds like something fried.
Otherwise, use jumper cables to go from one battery to the next and avoid the "internal" connection.
How do I check fusible links? I'm a newb to auto mechanics and had it installed at Mudrak's.
Also concerned why the aux battery would not be at full power if no accessories are hooked up to it.
Right now IBS is showing 12.6v for both. How much power do i need to start the engine?
Truck started now. Waited a while and seemed batteries recouped power.
Im concerned though, luckily it happened in a grocery parking lot and not the middle of backcountry Joshua Tree.
Will need to do more search on mud about possible issues with the aux battery but any pointers in the right direction appreciated.
I've seen quite a few starter issues in the extreme heat. Just helped a fellow mudder last weekend with his. I few taps on the starter with my hi-lift handle and it started right up.
I doubt it's a battery issue. Fuseable links or maybe the starter is going.
I second this. If turning the key made a click sound (coming from the engine bay) I'd suspect your starter contacts to be bad. Sometimes rapidly tapping the ignition can convince the starter to work but the contacts in the starter or the starter itself should be replaced/repaired.
It's also possible that worn wiring or an old fusible link could reduce voltage going to the starter. Your fusible link looks kind of old, I'd replace it for good measure. Checking voltages at the starter with a multimeter would rule out bad wiring or a bad fusible link.
I'm not familiar with IBS. Could it be that it can't pass full amps required to start the truck? Once combined, the auxiliary batt can slowly charge the main to the point it can supply enough power to start the truck. Your scenario shows that this may be the case.
Batteries are good according to voltage. Fusible links, battery cables, starter or ignition switch wire are suspect. Change fusible links, inspect/replace battery cables, rebuild starter, then if it still doesn't crank occasionally, then 94 delayed cranking. Starter, ignition switch, or other?
Agreed, not a battery issue if you're somewhere near 12v, you got something else going on !
For you guys saying fuseable links, are those pretty much on-or-off, not really "sort of" working?
We've all seen crazy things with questionable fusible links. My rule of thumb is that I replace them if they look sketchy or if I have any symptoms that could be attributed to the fusible links. I also keep two spares in each of my 80s.
Sounds like starter. Mine did the random no crank issue for a few weeks before I replaced it. When it did it I would sometimes be able to click the key on/off rapidly and it would go or just have to wait a couple minutes and keep trying.
Either replace it completely or get a rebuild kit for the contacts. I replaced mine with one from autozone with a lifetime warranty and rebuilt the factory to have as a spare.
Just FYI, and not saying this is happening, you can have a battery show full voltage - 12.7 volts or so and then drop to 0 when you apply any kind of load.
Remove everything attached to the positive battery terminal, clean each one, and reattach. My starter quit working, I replaced the starter, new starter didn't work, I cleaned all the lugs attached to the terminal, and it went back to working flawlessly.
Sounds like the starter, I know for a fact that you only need 11.9v to start the engine. Next time when this happens just bang the starter with something and it should start right up, replace your starter soon.
