Have to come to the forum for RTH. Haven't had this happen just like this before so here goes.
Kinda long but trying to answer all the questions the forum might ask up front.
Recently did a ton of work on a newer to me 97 FZJ80 (new water pump, alternator, radiator, oil pump cover gasket and crank seal) but also new fuel filter, #2 knock sensor, Fusible Links, AM1 block, and replaced the distributor (used unit), new O-ring, cap and rotor, and one new spark plug wire.
It was running fine before I started but needed the usual pm done.
The vehicle has sat for almost five months after I started the work and just got back to it
this past weekend.
So with a fully charged battery she cranks fine, once or twice I felt a stumble
right after I released the key, like a very brief bumpity bump. Not sure what that was
but no smell of fuel or exhaust.
I get the MIL light with the key to the ON position (new Fusible link bundle).
Checked all grounds and harness connectors to be properly snapped together.
All fuses look good.
I have spark at the coil wire.
I have fuel in the tank (put in Stabil before storing it five months ago).
No firing after spraying (3+ seconds) Starting Fluid (Ether) down the PCV valve hose going into the intake, or again down the breather hose going into the throttle body, with and without pressing on the pedal to open the butterfly.
I've rotated the distributor over it's entire adjustment range to see if that would
make a difference, nope, not one pop.
Before I removed the distributor at the beginning I took a photo of the position of the rotor,
then match it up when I reinstalled it, but I guess I could be a tooth off.
I'm 99% sure I did not move the crank pulley while the distributor was out
but it has been five months so don't recall every step. I'm also 99% sure I had the distributor
in when I tightened down the crank pulley bolt (and moved the crank to line up the holes
for the tool to hold the crank)
So that's it, crank and won't fire with good spark at the coil wire and Starting fluid.
If anyone prefers, send a pm.
this past weekend.
