Ok it is loose, 4 screws, the bottom bolt, and the 2 nuts are removed, the connector unplugged, the pipes disconnected, but I can't seem to get the thing back far enough to clear the firewall.
Do I:
1. need to remove the lower heater duct? How? I took the one screw out and dropped it some, but does it snap in or what? I think if I get this out the evap box will drop a little lower and the big pipe will clear the firewall opening. The top left (ashtray side) of the evap box is hard against the curved dash cap brace and cannot come back further, but if I drop a little more it might.
Took a break from wiggling and cussing. Hope someone has some trick I don't know. Ive searched and read but no dice...
Do I:
job if the evap would clear the lower right duct. FSM is no help with this duct assy - or I am not looking at the correct FSM. There are 2 screws and 3 plastic retainers that look like Phillips head screws but just rotate when you try to unscrew them. Do they snap out? I'll try the pry-n-turn trick.
