RTH fusable link???
Minneapolis, mn
Attached are pics of what I see. I've never dealt with a fusable link issue before. I obviously need to replace the wire and connectors but do I need to replace the black box also?
The black box is simply a junction box with 2 stud terminals. If the terminals are not loose or broken off the plastic, then it's fine.
The links come as a set of 3 from the dealer. Plug and play.
So it's just a junction box? Great! Studs seem fine, but the Dielectric grease seems to have cooked a bit. We'll see once I replace that wire I guess. I'm assuming its just an old wire and that's why it let go... Or would I say hoping.
Thanks.
Now I need a bandaid while I wait for the Toyota parts to show. Any suggestions?
Maybe a section of wire and an inline fuse as a temporary fix. A slow burn fuse may be best.
I'm off to the parts store. Now which gauge do I need is the question??? 14,16,22 (per the fsm)
I just used what I had in my truck to get me home. it was probably 14 or 12 as that is what I typically have laying around.
In an emergency, you can just use a crimp type butt splice to reconnect the wires. If it burned out (as opposed to pulled out or mechanical severing), then there is a short in the circuit and that would need to be fixed first or it will happen again.
Block assembly, junction. I finally got what I needed it took couple tries at the parts counter before we actually got it here in my hands.
Part number 82670 – 60040
