you should not need to worry about having the ect pattern switch, the only timing that it changes is the shift timing in the trans. it will hold out gears longer and will delay tq converter lock up. it looks like when the switches are pressed the signal gets grounded in the ecu so it should be a non issue, no button = no signal
