RTH Constant Misfire
Union, Ky
Hello, I have a 93 1fz and I just rebuilt the starter and now I have a constant misfire. It ran smoth as butter before hand. I tried messing around with the harness plugs next to the starter since I moved them around during replacement, but I'm not having luck. I don't have time to trouble shoot at the moment since I'm in college and have lots of tests coming up but I will try to do some work on it tomorrow. This is my only means of transportation to school, so any help is appreciated. I'm familiar with a multi meter so if anyone has ideas on what to test that would be helpful. I don't think its a spark problem.
Working on the starter should not really affect the spark plugs or wires, but you may of moved/loosened a fuel injector harness. Get up high and look down between the intake manifold and the valve cover to see the injector harness. Gently wiggle each injector clip with the motor running and see if one of them makes a difference. John
Just went out and moved every injector clip around with a flathead while it was running and no difference. Also tried the harness by the EGR, IAC, TPS, MAF, coil, and distributor with no change.
Thank you for following up and posting a close to your issue. So many threads just fade off with no solid resolution.
Keep in mind that you can still have a check engine code even if the light isn’t illuminated.
First step of diagnosis for us obd1 guys should always involve pulling the check engine codes.
Good to know.
