RTH: Brif Assembly double check
Germantown MD
I need a peer review. I have seen Raven's thread but for some reason my assembly looks different than Raven's.
https://forum.ih8mud.com/showthread.php?t=13063&highlight=assemble+birf
Is this assembly of the birf correct? I would install with the balls of course once I confirm.
TIA
hmm, the cage looks too far out to me.
Is the cage the center ring between the spider and the outside "bell"? If so, it is inserted so that the wider opening is facing towards the camera. Is this correct?
Let me know if more pictures will help in analysis. Want to do this right the first time.
Thanks for you help.
It looks right to me. I just repacked my birfs recently. The other side of the cage has a larger flat surface due to the smaller opening. The other side of the spider has a counter bore cut into it for the axle snap ring to pop into.
