RS3000 Programming issue
Southern Utah
All,
I have done a search for this specific problem and could find it so I posting to the community for some help. I have a 97 Landcruiser with a factory RS3000. I bought it without a keyfob and purchased an OEM older model that was taped up. I was able to program it but it finally gave up the ghost. I decided to get a cheaper aftermarket fob and could never get it to program. So I decided to get one of the new OEM fobs for the RS3000.
When I follow the instructions it appears to do everything it's suppose to. I press the green button on the unit and wait, then I press the button on the fob and hear the three chirps. I turn off the ignition and the key fob doesn't work.
This is the same thing that happened with the aftermarket fobs. Curious if anyone has a solution or if I should just take it to the dealer.
Thanks for any help.
For what you have spent (time and $) you could have put in a Viper and added remote start.
You want my RS300 junk I tore out?
You pay priority mail flat rate box shipping and it's yours.
Worked upon removal.
No matter how much you polish a turd you always have a piece of.....
I'd be interested in it - if it has 3 connectors and worked ok; as mine is toast
Will send you pictures.
Was working when I removed and I put whole assembly in a box and it has been on shelf since.
Want to buy 2 remotes that worked with it as well?
don't need the extra fobs but could be useful to have. Depends on price
That is my experience too. I can repeatedly reprogram my OEM fob, but I tried 4 different aftermarket fobs that were "guaranteed" to be compatible and none of them would pair up.
Who needs a remote on a 20 year old vehicle? There is plenty of other minor stuff to go wrong.
Fobs no longer Available.
I purchased 2 from CDan a few months ago, $65 each. Did you try Beno? They do not look the same, but they operate much better.
Today I will send pics.
I found the glass breakage sensor as well. It is not in the picture.
$10 for Priority mail flat rate and it's yours.
