New to the whole 80 section. Have just purchase a 93 80 series this week. One issue that I know the 80 tech gods will probably be able to solve.
When I got the vehicle it was having a real violent shift when going from park to reverse. No metal sounds or anything (did a search) but shifting real hard. At this time I noticed the RPMs at 1200-1300 when putting it in gear. My first response was to put my foot under the pedal and pull. Rpms went down to 900 with the A/C on and about 650 with it off. So I think the cable needs replaced or lubed. So I used a combination of Lithium grease and wd-40 a lubed inside and outside aroun the cable and throttle body mech. This has fixed a lot of the problem with the cable. But there still seems to be a lurh when going from park to reverse. Should this be smooth? You can feel the vehicle lurch down. Have yet to check the u-joints or grease them but I was thinking there might be a mechanisim that tells the tranny that you are going in gear and it's not getting the signal.
I have noticed when manually opening the throttle body and letting off there is about a 1/4 inch at the end that it stops and then slowly closes. Is this correct.
Watch ya think?
And feel free to give an "Oh crap that tard is in here now."
Watch ya think?
