Rough Idle ONLY When Cold Started?
Tempe, Arizona
This has plagued my lately (past month or two) and I can't pinpoint when it started. When I cold start the truck it rumbles quite a bit, the idle sounds weird, and it revs oddly below about 1500; as soon as I get down the street it clears right up and idles as it normally should.
I've sprayed every vacuum line in the engine bay with carb cleaner, as well as the hose between the aircan / intake manifold and I never managed to have it change revs.
There are no new codes, just the usual EGR related ones that have been on for over 40k miles.
There are 5k miles on the spark plugs.
I note that it goes away very very quicky and only happens on a dead cold start. If it was warm at all there is more or less no issue at all.
I've seen the posts about the wires being fried - is the the wire package to look in:
Mud :flipoff2:
Thanks for any ideas.
Poser shot :flipoff2:
Uhh, first thing I would do is remove the hood and drive the rig to a car wash, and let it cycle a few times:grinpimp:
Ok, just kidding, sort of.
Yes, that is the bundle. Regarding your funky start/idle problem; I'm sure you've already looked for all the usual suspects.
Sounds like it is not getting the correct air-fuel mixture when cold.
With all the mud on your engine, it tells me that there was also muddy water on your engine which can get into all the connectors, etc.
I get hammered whenever I mention this, but personally, I would disconnect the battery, and use some sort of gentle soap, and gently wash off the engine. Then I would start pulling engine harness connectors (including MAF, IAC, TPS, etc) cleaning them with the CRC spray for quick connects, adding dielectric grease, and putting everything back together. I'd pull all the ignition wires, the coil wire, and the distributor cap, clean all that and button it all back up. I would triple check all air/vacuum hoses, the air filter too.
If you prefer not to use water to clean the engine, I would at least clean each of the major connectors and snap them back together.
Point is, with that much muddy water flying around, anything and everything could have gotten cruded up.
Of course most of this is general stuff; but once it is done, then you know what you got.
I have had issues with my cruiser not starting well on cold days! For example, I tried to start my rig and it starts up normally but as soon as I let go of the key the rpm drops and the cruiser stalls. I did that a few times and the same thing happens. I ended up pulling the choke (hand accelerator) and starting the rig and works fine. I leave the cruiser running with the choke pulled and after a minute I push the choke back in and drive off. I was told it's normal for my rig to do this since it has a carburetor and not fuel injectors.
Well, this certainly can't hurt. :) I guess I'll go through the ESM and get all of the component testing procedures (The ESM has this, or am I thinking of the great Honda and Yamaha service manuals?) then go through everything one by one.
Chibo; you mentioned that you sprayed the air intake hose/assembly; you mean you sprayed carb cleaner from the air filter side toward the throttle body?? Did you check the air intake assembly for cracks? Very common.
I sprayed the whole hose after the MAF very well. :grinpimp:
thestallionq8:
I'm not familar with your engine set-up, we did not get that model in the US, the last cruiser we got imported with a carburetor was 1987. I'm surprised that it is not fuel injected; what engine do you have? If it does have a carburetor, sounds like it needs a rebuild, or at least some adjustments (choke,etc), cleaning, etc. The guys in the 60 forum have carburetors. Might want to post over there for this question also; but you'll need to post what engine and carburetor you have.
Good luck.
Gray :
1FZFE engine with a carburetor and 5 speed manual transmission
Interesting, you guys get all the good stuff. We only get one engine type and transmission type, never a choice. Maybe if you start a new thread about your cold start problem you will get more replies in the morning (it is 1 am eastern now in the US). Good night for me.
My cruiser is going into the shop next week! They will check on that as well as the leak from the center of the rig!
New symptom upon leaving work - Idled at 1800RPM and slowly varied between stoplights on the way home. When I got home it settled down to about 800-1000rpm. I assume this is the wiring issue.
Have you checked your throttle linkage? Is it sticking or hanging up at the throttle body?? Is the cable moving in it's housing freely? I would clean the throttle linkage and lube it. Have you had a chance to look at and clean the butterfly with the air intake hose off; is it moving freely?
While you have the air intake assembly hose off, you could clean the MAF connector with CRC connector cleaner, and the MAF wires with the CRC MAF sensor cleaner with the key off (I disconnect the battery just in case). Do not substitute carb or brake cleaner for either of these IMO. Do not take the MAF apart IMO.
I would not recommend spraying throttle body/intake/carb cleaner through the air intake hose/assembly, most of it ends up on the bottom of the hose, just sitting there. Remove the air intake hose from the MAF and the Throttle body, inspect it for cracks, and then clean it off the vehicle.
I'm thinking it's the MAF because the truck is in open loop during this time and if the MAF was slow to react then the ECU won't be compensating for it.
Do the MAF wires run through that package of wires next to the EGR?
The CEL has been on for ages. IIRC OBD2 cars run open loop always when the CEL is on, is this wrong?
I'm still thinking it has something to do with the package of wires that seem to have issues near the EGR pipe. I poked at them today and nothing immediately changed but maybe...
I'm referring to this:
https://forum.ih8mud.com/showthread.php?t=118026
What code(s) are you getting? Missed that part. If you haven't checked, you could take it Autozone etc and ask them to pull the codes for you (unless of course you have your own code reader).
I've got my own code reader. P401
My long running performance problem was finally solved and it turned out to be burnt wires in the harness where it's against the EGR pipe. On mine, the burnt wires were those going to cylinder 4, causing a misfire, and wires going to the IAC causing an intermittent, low or highly surging idle. These were all the wires right against the pipe.
edit: I just started it up and it idled fine :rolleyes:. I pushed and pulled all over that bundle of wires and it didn't have any issues. What a pain. :rolleyes:
I suppose I'll grab the ohm meter and test the MAF. Does anyone know what the resistance should be, I left my FSM at work. :mad:
The voltage to the MAF from the harness should be 9~14 volts with key on, measured between terminal 1 of the MAF connector and a body ground. There's like 3-4 pages in the FSM for troubleshooting the MAF circuit via the ECM. too much to write down here; can't scan it, but nothing about checking the resistance of the MAF itself that I can find. If the MAF itself was the cause, I would think that you would be getting a P100 or P0101 code, unless too intermittant to send a code?? Seems a quirky problem like from a short/break in the harness (if there at all) or the connector itself. ie: if the ECM looses the signal from the MAF, the FSM says that the ECM goes into a default mode. Landtank is the expert here. But that wouldn't explain all the symptoms??
