Rough Idle ONLY When Cold Started?
If the MAF itself was the cause, I would think that you would be getting a P100 or P0101 code, unless too intermittant to send a code?? Seems a quirky problem like from a short/break in the harness (if there at all) or the connector itself. ie: if the ECM looses the signal from the MAF, the FSM says that the ECM goes into a default mode. Landtank is the expert here. But that wouldn't explain all the symptoms??
Indeed. This stuff is really weird. :frown: It takes a LONG time for the car to be 'cold' enough to have the symptoms. I just let it sit for 2 hours and it started up, did the completely normal ~1050rpm warmup, and idled fine. I think I'll have to video tape the thing in the morning then throw it on youtube. I wonder if this is just something to toss away in my mind as a minor quirk since it doesn't effect driveability. :rolleyes:
I'll be trying a few things you guys mentioned earlier. I'll clean the MAF and check all the connectors/plug wires/etc for resistance, as well as throw dielectric grease in them. :)
Bringing up an old thread, but what was the final solution?
