- Joined
- Oct 14, 2005
- Threads
- 5
- Messages
- 65
- Thread starter
- #61
cessna170b said:Cool rig! You did an excellent job on your 80 in a short period of time. I really like your drawer system. I was wondering if you could share the details on the drawer sliders and handles. Where did you get them? Do you have any more pictures of the drawer construction? Thanks for the help and the excellent write up!!!!
I did the design on the box but my brother is the one with the crazy wood skillz. He does custom cabinetry as a side-business and did most of the work on the drawer system. The box and drawers are all three-quarter inch AC rated No-void plywood. All the structural joints dadoed, glued, and stapled.
It is sized so that the boxes themselves fit just between the wheel wells. Then the top (which must be attached as a separate piece or you will never get the whole works into the back) goes directly over the wheel wells (in fact it sits on top of them for support). This height also works out so that when you fold the rear seats down, they are at the same height as the top of the box. I imagine one could get an Aerobed matress and sleep in there quite comfortably.
The covering is rubber-backed outdoor carpet from Home Depot. It is attached with screws and finish washers (to keep the screws from just going right through the carpet). The screws sink into the carpet enough not to get snagged on gear as you load/unload. The metal edge guard is also from Home Depot and protects the box from getting gouged up when loading gear. The whole thing is finished in clear polyurethane.
The slides are manufactured by Knape & Vogt (USA) and are the 40” size. Model KV8900B-40 Full Extension. The are rated 300-500lbs depending on application. I purchased through USA Cabinet Hardware ($142.55 per set). It is critcal to get VERY heavy duty slides or the drawers will flex when extended and hit the tailgate. Mine don't flex AT ALL even with quite a bit of weight in there.
http://www.knapeandvogt.com/kv/Draw...0+Extra+Heavy-Duty+Slide.htm?NRMODE=Published
http://www.usacabinethardware.com
The pulls are manufactured by Nielsen Sessions (USA). They are the "Spring-Load Recessed Folding Stl Pull Handle Dull Black, Cushion Grip" I purchased them through McMaster Carr. Their model # is 13195A63 at $10.30 Each
http://www.casehardware.com/products/category.asp?catid=2
http://www.mcmaster.com/
The slides are very smooth and if you are parked on the slightest hill and open the tailgate, both drawers will come sliding out and hit you right in the . . . lap
So, for the latches, I wanted something that would hold the drawers closed and was lockable but didn't require a key every time you wanted to get in there. What I ended up using was a fence latch from Home Depot. Just dig through the bin to find 2 with the same key number so both drawers will be keyed alike.Hope that helps. Here's a couple more Pix:
