NorCalBorn
- Joined
- Aug 31, 2008
- Threads
- 101
- Messages
- 1,855
Sounds good. Keep in mind my actual days of what I consider wheeling are on hold for a little until I go ahead and have a budget for another 90's 3rd gen pickup or Taco, but definitely keep an eye out there are some events we're trying to make in the next year.I'm a little over the "Go goof off at Prarie and Hollister" bit. I am loving the travel trips though. This last trip around the Sierras was great, and bonus was only a couple minor issues. I would love to do a trip out to the Nevada Desert again.
Thanks! You're location says SantaRosa, correct?
You should consider (if we're able to still make it) coming out to the Pacific Mountain Cruisers Toys for Tots Drive on Dec. 5th at YodaMan's shop. You can check things out, shoot the breeze and meet lots of peers. Although we are not members of that specific club we're planning on going since it's related to IH8Mud and TLCA, besides, we hear they're a good group of people.
The gaskets were replaced with Rock Gaskets since they're easily available and no I believe they only needed a light surfacing since I was lucky enough to catch the issue as it was happening. I've yet to see a set of these last more than 160k, so I was in a way prepared. Besides, the 3.0's can also develop some cylinder ring walk where the rings openings end up lining up causing a compression loss. It was time to check things and we found a couple little dealership tech cheat fixes I wanted to remedy anyhow along with retaping up the looms.
As for the headers, no they're dual exit with the crossover going under the front driveshaft and transmission. The wiring and hoses are moved out of the way, along with better insulating on the floorboard and a 1" body lift to clearance it all better. I am also picking up (*hopefully really soon) a new ~Transmission Tunnel-Firewall Insulator piece and a ~Hilux Surf RHD Exhaust Collector Heat Shield. The insulator to stop a little more of heat from coming off the back and the shield's the RHD version to insulate the floorboard. Basically using the U.S. and JDM spec insulators in conjunction lets you have a cooler running setup with both collectors shielded, make sense? This would be the LHD one.
