Rops Roll cage
Rotorua, New Zealand
Just a couple of pics of the safety cage that I installed last summer to help anyone with ideas.
I've been in to many scaring situations and decided to add some protection in case of a roll over.
I realise it should have more cross bracing but this is an adventure touring wagon. This is not a race cage.
The bracing behind the front seats is where the mounts for the 4 point harnesses are now fitted.
1913641
1913641
1913644
1913643
The bracing behind the front seats is where the mounts for the 4 point harnesses are now fitted.View attachment 1913641View attachment 1913641View attachment 1913644View attachment 1913643
Do any of the feet go down to and connect with frame supports or crossmembers? That's where the strength will come from or the risk is that they will just push through the floor. I realize you have "feet" inside to spread the load, but I'm asking about structural points, not just pressure on areas and hoping the body will support it. I know the ones on top of the fender wells will not support much.
I studied a fair amount of this in college for tractors / skid steers / Ag equipment that would be VERY heavy if rolled over, so the side impact and roll over part had very high loads.
Love the idea, but it honestly looks like you could use more triangulation in the cage. Unless that V is actually an X and ties everything together. How's the clearance for your head with those vertical bars next to the seats?
His design is correct for a body-on-frame vehicle. The strength of the installation is still a question, but he has the right idea. You can't connect a roll cage to the frame on a body-on-frame vehicle. If you do, in the event of a rollover, if the body mounts shear, you have a serious problem. Building the cage into the body keeps the entire passenger compartment together.
Edit: This applies to cages for off-road applications. Roll cages for racing are a different matter
Thanks for the input.
'Feet' have a larger plate under the body that sandwiches the body. All are overlapping points on the body where it has strength and framing.
Not shown is the forward bars, windscreen cross brace and braces from the centre hoop feet forward to the driver and passenger foot wells.
I realise x members and more cross bracing would be the best, but I wanted a vehicle which was still functional and comfortable with much improved safety for its occupants. Im 6.2 and my boys are taller than me so cross bracing across the roof was not an option.
all is wrapped in race foam so no my head cant bash the pillars with the 4 point belts.
ill chuck up a few more finished pics later.
Something I learned.....
On the plates above and below the body..... Make them different sizes. Otherwise, they act like a punch press and "punch" a hole through the body. Make them about 1" different in all directions than the one above/below.
I like it, but I do have to add one more thing. Anytime I ever rode in anything that had that much of a roll cage, helmets were always mandatory. The reason being, smacking your head on one of those bars, even a padded one with a helmet on SUCKS. I don't even want to imagine what it would be like smacking that bar, even a padded one without a helmet on.
