roofrack mounted solar shower
New Rack Mounted Solar Shower
I wanted a good solution for showering in the back country. I think this invention solves a lot of the problems of other showers. Thank you for looking at this post. Here is the correct photo of the unit.1-ROADSHOWERwithlogo.jpg
PVC or ABS is not better than aluminum. It is brittle and can break. It is an insulator, so it does not transfer heat to the water very well. That's fine if you want a luke warm shower. Your home made unit is going to need to be strapped on, there is no built in mounting. And if you pressurize it, there is a risk of exploding plastic, if you do not buy a pressure relief valve.
Check out the new aluminum model...works great, and will last you a lifetime.
Please check out my kickstarter project:
http://www.kickstarter.com/projects/...d-hot-water-on
Please share the link with your friend who might spend some time doing outdoor activities, or traveling in their vehicle.
The new camping Solar Shower
It is like adding plumbing to your vehicle! A green solution using renewable energy.
With the Road Shower you can have pressurized water wherever you go. It will heat the water while you drive and will be ready to give you a high pressure hot shower at the end of the day. Hot or cold, the Road Shower has many uses from the camp hose for dishes, gear, pets, or for extra drinking water. •
Storage capacity: Holds 5 gallons of water good for 2-3 showers
•Solar heated: Water can heat up to 100-115 degrees.
•High Pressure: Can be pumped with a bike pump up to 15 PSI.
•Safe: A pressure relief system is built in for safety.
•Easy to mount: Included hardware for Yakima or Thule racks.
•Tough. Made from powder coated high quality aluminum.
•Non toxic: You can fill it with drinking water.​
Looks like a nice setup. It looks like mounting to Thule or Yakima racks is the way to go, but how about attaching to expedition-type racks; e.g. Front Runner (see image below)?
From the pics on your site the bottom of the tube looks like it fits a hex-head bolt. The Front Runner is similar and accommodates an M8 bolt. Any ideas on how to attach it to the Front Runner?
BTW - The link to the Kick Starter project doesn't work.
Thanks.
Road shower - your links up top don't work. I can't get help from expedition portal to get signed back on and the other one is u/s.
Hey guys I tried out the Road Shower and I also like to make videos so I did a gear review video on it. I'll post the link!
Very nice review.
I was thinking of getting one of these when I saw them earlier, but I ended up with a nice propane one that fits in the back of my FJ Cruiser pretty good.
I decided to give one of these a try
