Roof racks
Home of the JSF
Website
www.thereligionofpeace.com
Do any of you have roof racks (like an ARB) on your 80 that came equipped with an oem roof rack? Did you just install it over the oem rack? The oem rack does not look like it's made to come off without jacking up the roof. Also.....the few that I see that have their spare tire on the roof rack, HOW in the hell do you get it up there and down when you need it by yourself? A 33" tire and wheel ain't exactly light.
The 'B' portion of your question...
Quite a few people have removed the port installed (OEM) rust rack. Removal does leave holes in the roof, and quite a few creative solutions have been found as a result.
My rust rack and spoiler is off the truck. I put in stainless steel allen headed machine screws looped in teflon tape and then had the roof done in color matched LineX. I'm known to go a bit overboard though.
YMMV.
Factory rack is easily removed....
Some opt to fill the existing holes with silicone, but I just installed new bolts and rubber grommets to keep the water out....
I figure if I ever feel the need to sell her (don't see that ever happening), I can still put the OEM rack back on....
As for getting up there, my rack has an opening so I can just climb through the moonroof ;)
I have a homemade safari style roof rack that I mounted over the factory rack using quik-n-easy clamps. They lift it high enough to go over the existing rack. I really did not want fill any holes.
I put my 35" tire on the roof rack by opening the back all the way. Then putting the top hatch back down with the tailgate still down to give me a place to stand. I lifted the tire up on to the tailgate, climbed up on the tailgate with it, then lifted the tire up onto the roof rack. Not too much of a pain.
Now I have a very coooooool 4x4labs rear bumper that has a tire carrier and gas can holder. Muuuuuuch better now.
Some older pics:
I just installed a full length ARB rack and it did not clear the OEM rack so the OEM rack was removed. It hit at the middle gutter support. Others have claimed theirs worked but mine didn't. As for the old holes. Use shorter screws and black 3M 5200. Should be fine.
i got my idea from tinstar. mine is custom made. the quick n easy clamps work great! i did not want to fill any holes! clears the rack with plenty of space. :cheers:
I also pulled my factory rack and filled the holes with silicon and stainless steel machine screws. I am going to look into a more permanent fix, but this is doing the trick for the moment. I could see rust starting on the surface under the feet of my factory rack, so removal was my only option. I don't want to fix rust on the roof!
Yes, ARB fits fine over the stock rack.
If a 33" tire isn't light....than a 35" tire is even heavier, and my scrawny self manages loading and unloading the spare just fine. When I had it mounted on the back of the rack, I would just open the bottom tailgate in the rear and close the top of the tail gate. I could then stand on it like a big step, grab the tire, lower it to the tailgate, and then hop down, and bring the tire to the ground.
Now I have it mounted on the front of the ARB rack.....so when I want it down, I'm just gonna throw it like a discus.
Where did you source the quick n easy clamps. I found them for about $70, does that sound right?
Depends on how many you need....
I found 4 for $40 bucks and bought another set a week later for the same price....
Then again, the ones I have are low profile (4"), so you would have to add spacers to clear the stock rack :doh:
This is the rack Mot got me. It's an all aluminum Aiba Works Mid or Noselda Wagon rack from Japan. Very cool rack with huge/tough feet and a bridge kit for accessories (currently holding RTT). It's strong enough that I can walk on it up there with the tent mounted. It can be completely disassembled and is very light weight. It has black plastic boots that cover the feet, but I like the polished look of the exposed lock plate. I took the stock rack off as the feet are very large and the nuts hit the side bars. The bridge kit's load bars are held by bolts that slide in channels and can be locked down anywhere on the rack by tightening the knobs on top.
I saw a bunch of nice racks at CM. None were as nice as this. The only mod I plan for it is some new corner pieces so I can run it without the upper rails. If anybody else has one of these here in the states I'd like to see some pics. Big thanks to Mot for finding me a deal and making it happen.
I have had trouble locating a source for roof rack clamps for the rain gutters. Does anyone know where I can look to see if there some that is something I can use? I guess it would be just a universal gutter mount with some adjustment flexibility.
Thanks
I think the quick n easy ones the other guys are using, quick and easily mount up to the gutters.
Snake Eater, two questions:
1. Where did you source them? The ones I found were $70 for 4. I'd much rather pay $40 for 4...:grinpimp:
2. NICE RACK! I love the horns and really want to hear them. I don't think it matters where you live, just let me know when you're gonna blast 'em, and I'll open my window and listen!:beer:
I went to tighten my OEM rack as it was loose, but the phillips heads just spin (loosening or tightening). I gotta git rid of that POS, any suggestions before I get fed up and bust out the Sawzall???
I drive on 315s and can put the spare on the rack and take it down by myself (I'm only 5'8). It just takes a little grunting. :)
I got my quik-n-easy clamps for altrec.com. Here is a link:
http://www.altrec.com/shop/detail/4386/?sch=clk
Its $70 for four. I called the manufacturer direct, it was the same price but Altrec had free shipping.
Thanks Chris, those look like they will do the job for me. I may want to paint or plasti-coat them black but they might be fine the way they are.
