roll on liner
Wow, you decided to just do it with the flares on huh? How did that work out where the rubber seal hits the Herculiner?
What kind of tape is that it seems very easy to curve! I used that blue painters tape from home depot and used 1.5" on the curves and 2" on the straight. I had to use a ton of little pieces (See Below) to make the turns the way I wanted. And I can't believe you didn't roll past that narrow tape, I did a few times but kept a rag on hand at all times.
I didn't do the bug deflector either because it just looks too funny to me, I have been searching for a gray hood bra but haven't even found black ones.
the tape is actually automotive painters tape. or at least thats what I was told a few years ago. It flows/ contours much better than other tape that I've used in the past.
Right now the Herculiner is doing quite well on the rubber seals. The only problem that I'm having at this point is that the previous owner had it re-painted at some point. They didn't Tape off the rubber strips or even pull off the flares for that matter. So, I had some flaking where the other paint peeled up. I regret not sanding more on that part. Otherwise the rest went to the primer. I'll probably spend some time with a razor cutting it off around the rubber seal/trim on the flares.
I did go past the small tape a few times. But I also carried a small rag with me. :D
Now I need to pull of the lower valence on the front, and get inside the doors too.
i could go crazy with this stuff! I just dont want my rig to look tacky if I do too many detail items and not the whole thing.
Not sure what you are talking about with the lower valance pulling off? But I did the part below the door while I did the rest and I had problems with pealing on the edge.
So I had to go back and do some touch up and it is now holding up and taking the abuse of getting in and out.
So my advice is to tape your jams and wrap it around the edge.
sorry, I meant to say that I was going to pull the front bumper to get to the lower valence and pull out the turn signals and grille.
your advice is well noted. i think I'm going to use it.
have you been happy with yours so far? how long have you had it done?
I did it the middle of August. I think I am finally used to having stucco on half of my truck but I have yet to wheel it. I will be in Death Valley in 2 weeks for the REAL test.....
But so far the Durabak has not lost it's shine and everyone thinks I had it professionally done. In my opinion it looks good from far but far from good but I am real critical.
a few more pics
I got a chance to snag a few of my truck in the day light hours. I took them with my cell phone since I left my camera at home. I'll take some better ones soon.
