Rocker Choppin
I sealed the whole thing up. going to be durabaking it and then moving on to the sliders which will go in place of the rockers. Easy 3" of clearance vs. sliders residing underneath the rockers.
Im holding off until i do a 1" body lift and then going to tuck sliders high n tight.
In theory- 1" body lift + 2.5" frankies plus the 3"+ clearancing of the rockers..........will effectively get me what a standard 6" lift will get on the rocker area.
Looking at doing this in the next couple of weeks. What should be done about the B-pillar? From what I can see it is actually tapered into the inside wall of the rocker panel. Would that need to be reinforced? I was thinking a small sheet of 1/4 just larger than the pillar could be welded at the bottom to add that rigidity. I was also going to use some 1/8 sheet to make the bottom flat then do a box slider under that that's attached to the frame with some tubing off of the side for a little breathing room and to act as a step. Anyone have any extra input?
