I removed the valve cover to set the valves. After removing cover I noticed the area was extremely dirty with grime. I remove the entire assembly for cleaning. I marked all parts cleaned and put assembly back together. I believe the rocker supports are all position correctly with the larger hole towards the driver side. The unit will only go half way onto the studs. Having trouble getting this assembly back off. Any ideas?
