Rock sliders
LA, CA
Hello,
Just purchased my first FJ80 yesterday and already working on some TLC. It's 1996 and pretty much stock.
Planning to build it slowly .. and would like to start with rock sliders. Ideally, bolt on if available, but otherwise anything sturdy should do the trick. Any advise?
Thanks in advance!
Welcome to the MUD community :flipoff2: (newbie salute). The forum allows each user the opportunity to use the search function for a wealth of information. In search (top right corner) type in White Knuckle Off Road Sliders. The beauty of this forum is how long it has been in existence. Literally every part of the rig has been dissected, discussed, and reworked multiple times. You will spend about $900 for the sliders and they are bolt on. I believe that company will offer a group buy occasionally. Search for a 5% off code here on MUD that you enter into their web site. 1996 needs catalytic converter protection and WKOR provides said protection.
Go extremely slow on your modifications if you have never owned a Land Cruiser before. In stock form, they will amaze you. In addition, we are a visual crowd so post some pictures of your new ride.
Are you looking for one that is more for a step or one that is more of a true rock slider? I run OPOR sliders on both my 80s. They are less of a step and more of a wheeling slider, although they do help some in getting in. They are very stout are reasonably priced. Bought them from MetalTech in Newberg, Oregon (not far from me). They typically have a Black Friday sale or other sales.
Thanks for the input, will look into it. Need it more on the rock protection side.
I just ordered WKOR sliders earlier in October. They are still honoring a 5% off code from their thread in the vendors forum section.
Not sure how I've missed this one .. :) thanks
Looking at White Knuckle Off Road Sliders, noticed the following options:
Suspension Lift Compatibility​
No Front Control Arm Drop Brackets, Front Control Arm Drop Brackets
Body lift​
Stock, 1 Inch
Outer Round Tube Angle​
Angled Up at 20 Degrees (default), Angled Up at 10 Degrees (reduced)
As mentioned, at this point my rig is stock. However, I'm considering 3" OME (unless there're other suggestions) and not sure if I should finalize the lift before getting sliders.
I just received my White Knuckles yesterday from the powder coater. I had to go that route as I have an Iron pig slider. Sage advice from @Comet, mods on these rigs are expensive, (as is everything else) and your bank account can easily evaporate, especially when you buy equipment that does not work well with each other (I had Hanna sliders when I bought my Iron Pig, they interfered with the Iron Pig and had to replace).
If you go with the lift, forget the offset bushings for the caster correction, go with either the caster plates or the Delta radius arms. I will be calling Mr. Delta soon to place my order for the control arms. Also, before buying the lift, spend A LOT of time researching these. Nothing wrong with the OME, tried and true (I have one) but, they ride stiff, even with a load. The shocks, in my opinion, are valved too stiff as well so, overall stiff ride. I will be replacing with a different setup once I have a bunch of other stuff ticked off my list. Bottom line, research all your purchases and, check the Bad Sellers - Buyer Beware section under Classified before pulling the trigger.
i am super cheap plus have a welder so i went with trail gear 87s
Do you have pictures of those trail gear sliders installed? I have a set and have yet to install them but definitely wanna get them on.
not currently. i sold the last 2 trucks i had them on and the current one has a set sitting in the shop waiting to be installed. i can dig back and see if i can find some. i went with them after @thatcabledude told me how easy they were to install. he might be able to get some pics for you.
Body lift​
Stock, 1 Inch
As long as you aren’t doing a body lift then you don’t need to wait to order. Also, I ordered the 10° angled sliders so that they help a bit more with entry and exit. My wife is very short and needs all the help she can get.
I just snapped a bunch of pics. They are really high and tight.
Driver:
Passenger: as you can see, my exhaust is inside the frame rails. That bent pipe went over top of the exhaust when it was in the stock location. I had no cats.
@Azca, I totally forgot about the buyer beware thread. Great info there.
I went from saggy and tired OEM springs/shocks to the 1.5" Dobinson springs and OEM shocks on my 80 series. @crikeymike is the North American (USA) representative for Dobinson and he took the time to answer my questions and had a lot of his own before recommending anything. I carry myself and about 350 lb. worth of tools/spare parts/recovery gear in the 80 at all times. Again, get to know your rig and how you want to use it, research the proposed mods, search MUD for those who have gone before you, and ask more questions. I have even heard of other members who have the set up you are thinking about extend an offer to drive the setup. First hand experience is always recommended.
I have the WKOR sliders and they were a perfect fit, bolt-on. (96 LC)
I got the 10° version with no cover plates, I got the HD ones and plain. Then I cleaned and coated with John Deere Blitz Black epoxy primer and top coat. VERY HD on the paint as well.
I got the shorter ones, expecting to KEEP my mudflaps. After I removed the mudflaps, I realized I will never re-install them because they would get pinched and torn off doing any rock crawling. Now my sliders are shorter than I'd like, but they work very well! They also protect my cats.
Just a side-note. I just installed new exhaust two weeks ago (Magnaflow wye pipe w/ cat, MF cat, Borla muffler) and I was able to remove my old cats using a sawzall with one cut at the bottom of the wye pipe, and one behind the muffler, then unbolted one flange in the middle.
I was able to install the new MF wye pipe with cat without removing the slider! HUGE WIN!
Body lift​
Stock, 1 Inch
My understanding (and may the Mud Gods correct me) is that you can go 2.5 without altering stock geometry enough to need additional changes. Is the extra .5 inch worth the trouble? One-inch taller tires will give you the height, if not the load-damping...
It is hit and miss, even at 2.5" Some folks have vibrations (I didn't at 3" with a 20 mm spacer on the front) but others have not. Appears to be no rhyme or reason. I have the OME caster correction bushings, not happy with them. I am hoping the DELTA gods smile upon us this xmas with a discount as I really want their radius arms. Already have their panhard lift bracket and it did improve the vehicle control, just not enough to compensate for the caster issues.
Why would you powder coat a slider?
Time, I had two bumpers to do as well. I was going to do the JD blitz but, way too much on my plate. Working 12-14 hour days, 7 days a week now. Rebuilding my axles last week absolutely killed me, setting me back on several projects. I have to run out of town next week and I am literally booked through Christmas. So, off to the powder coater.
