FIrst time poster, long time browser.
So here is the riddle: Cold starts yes, warm starts no, but if you feather my key away I go.
Problem- Warm/hot starts, I mean 5 min, lukewarm starts. Will crank but will not start. Not every time, I wanna say 80% wont start when warm. Cold starts no problemo.
Solution- A quick turn of the ignition, just enough to engage starter, then back, then start normally. Starts every time. But only quick turn, if you crank and crank, stop and then try to start, no start.
Truck- 88FJ62, PO installed man-a-fre "FIREPOWER IGNITION KIT", I replaced FPR, pulsation dampener, new fuel filter, and cleaned throttle body(thanks guys).
Nothing solved the initial problem of warm starts. Searched and searched on Mud and 3fe yahoo group. Note, I am not a gearhead, bolts snap, screws strip, and knuckles bleed, when I start wrenching. So i stopped reading when the fuel pressure gauges where busted out.
The truck runs fantastic, never stalls, runs/idles smooth right @650 or 750 i forget which. Horrid mpg; 9-10, but I live in San Francisco, not too worried about that.
My mechanic, says the initial turn cycles the relays, then they are primed for the "real" start. He's Irish and been known to tell a fanciful tale now and then, you know how the Irish are great storytellers.
So what I want to know is, is ^ this the case?
Should I just be happy I can get it to start every time or is it a symptom of a problem that can be fixed?
Does anyone else have to do this?
I like that. Mine starts too easily. Better get to fixin' it.
