- Joined
- Jan 12, 2008
- Threads
- 300
- Messages
- 3,609
- Location
- West MI near GVSU
- Website
- www.mcdesignsoffroad.com
- Thread starter
- #21
Just "stabbed" the rear third back into the axle. That sucked! Gunna feel it tomorrow..
I know the level of skill required for fixing rusty parts. The % of mechanics that can complete the process drops significantly with Rust. Your doing a great job. When I first looked at your rear axle housing I said OMG I have never seen one that bad. Thinking the paint left on the rear diff was a HOLE, I enlarged and say the reality. Along with bad Arthritis, now my sight is going...! LOLView attachment 1159318 Pardon the Midwest petina... Got home from drill and set back to work on the 80. Still don't have a torque wrench for bolting down the head, so I finished stripping the rusty dysfunctional e-brake hardware from the axle. I'll build a tcase disc at some point. I'm about to dig into the rear diff to hopefully fix the non functional locker actuator.
I figure it's a good time while the driveshafts are out.
Is The Isolator the same as the steering coupler disc, or rag joint ? I had the biggest Improvement In my steering from replacing all TREs and wheel bearings when doing the full knuckle rebuild. I even replaced the steering box, a few Banana's for me. Bad arthritis, tight spot 39 LB piece equals discomfort. I would be Interested to read how that elimination worked for you. My 95 steers great now 850 J with Metal Tech plates, Its like a car. Good Luck !![]()
I know the level of skill required for fixing rusty parts. The % of mechanics that can complete the process drops significantly with Rust. Your doing a great job. When I first looked at your rear axle housing I said OMG I have never seen one that bad. Thinking the paint left on the rear diff was a HOLE, I enlarged and say the reality. Along with bad Arthritis, now my sight is going...! LOL![]()
Toyota calls it a "Flexible Joint". I just replaced mine so I could carry the old one as a spare. $42 at onlinetoyotaparts.com. Can you post a pic of the "shaft spacers" you installed. I'm having trouble picturing this.No pics, but I made my own firewall steering shaft seal and installed it tonight. No more drafts...
I also eliminated the rubber isolator in the steering shaft and clocked the intermediate shaft flange. To fill the length difference of losing the isolator I used two shaft spacers and grade 10.8 metric bolts. Hopefully it will tighten up the steering...
