Reverse + Turn Signal = Quick flash?
Albemarle NC
Something has happened in the last 2 days. Now, when in reverse, my left turn indicator glows slightly and if I put my left signal on flashes extremely quick. Flashes normal in any other gear, and normal in reverse right signal. What should I check? All lights seem fine, and I glanced at the fuses I thought might cause it.
Anything to steer me in the right direction would be great.
Sounds like you lost a common grd somewhere (guess) and the reverse lights are picking it up by back feeding thru the left signal lamp. If my guess is right you can remove the left signal lamp and you will have no reverse lights and you will looking in the right direction.
HTH
I had this problem a while back ago and I would advise checking out this link. Ended up unplugging the converter box from the truck side / not the trailer wiring side and all was well. There is also a bunch of other suggestions from people as well.
https://forum.ih8mud.com/showthread.php?t=70531
Messed with things a little more today, found out that the brakes cause most of the havoc. The left arrow glows when the brakes and headlights are on, but flashes normal, in reverse the arrow doesn't glow, but does glow when the brakes are one and flashes faster.
Well, got it all sorted out. One of the IPO's had spliced in a trailer wiring harness that had several shorts in it. So I cut the damn thing out and repaired the wiring with my l337 (elite) soldering skills with all the joints wrapped in heatshrink.
All is well! Thanks for pointing me in the right direction.
Problem is back, don't know about the quick flash, but in reverse, with the brakes on, the left signal indicator glows again. Everything that had been changed is now back to stock and anything that looked sketchy was repaired, so what gives now?
I reckon I'll have to open her back up tomorrow and see what I can figure out.
I have a similiar issue.
Did u fix yours?
what was it?
