Reverse switch on an A440F
Brisbane
Can anyone help?
I need to know which one of the eight or ten wires that come out of the neutral position switch on the side of my A440F is the wire for the reverse lights. I can't get what I need from the manual and don't want to pull it apart in case I can't get it back together again.
I'm guessing that they are earth active. Power to the reverse lights all the time and when the switch (gear selector) is put into reverse it provides the earth connection.
you will have 12V from that wire when you shift to R ... I did identify it when I was doing my manual tranny swap .. allow me to reach home and see which color was in my 80 .. ( HDJ80 95 with A442F )
Thanks, that'd be great. So does that mean it will be power active? So earth the tail light to the body, power comes from the contact being made in the neutral position switch when it is selected in reverse. So there must be a power supply to the neutral position switch as well?
The reason I don't know is that I have fitted the A440F to a HZJ75 and am starting from scratch with this wiring. It's in and running beautifully, but the only wiring from the neutral position switch I've used so far is for the neutral position, I tied that into the starter solenoid feed.
Sorry I completely forgot this yesterday .. willing to do it today .. please drop me a mail to tapage at 4x4panama.com ..
Reverse ( and actually all shift are power active when selected ) I just took those coming from square grey connector over bellhousing ..
Tapage, any idea if there is a wire in the engine bay that switches (either + or -) when it's in reverse? Or, in the kick panel area? Engine bay preferred. I have a relay in the engine bay that powers my reverse work light, I'd like to tie that into it so the light comes on with either manual switch or automatically with putting it in reverse.
I took the reverse signal from rectangular gray plug on my engine bay ( top of bellhousing drivers side LHD ) that was + when in reverse .. ( in auto tranny setup )
Thanks. Like, on the transmission itself? Can you reach from the top of the engine bay?
I did it from top drivers side .. that's the plug that goes ( wiring ) to shift selector on the auto tranny ..
