Reverse Birf Soup
Sandy Utah area
So I did my diff oil last night and the rear looked like it should for 10,000 miles, but the front...yikes. it was thicker, blackish gray and smelled bad. No metal in the oil, or on the magnet but it looked bad. It looked like birf soup, only I still had grease in my trunions and all my seals were replaced less than a year ago. There has never been any leaking from the birfs...can you get grease intrusion INTO to the diff from the trunion but not have gear oil pass TO the trunion? Bad seals? blocked breather? whats going on here?
It can go both ways. A bad seal lets oil into the birfs. And a clogged breather pulls grease into the axle.
This is what came out of my diff:
My breather was trashed
Ran it up to the firewall and replaced with a fuel filter
Did the same after a front axle rebuild.
Common, somewhat normal with the stock breather, as mentioned switch to a free flowing setup. But, the knuckles don't have breathers, so there will always be some migration, running cheap fluid and changing it more often, is the best plan.
Mine wasn't as contaminated, but basically looked like that. I have the fuel line to do a breather mod but haven't done it yet. Question: is it too late to just clear the breather? or is it new seal time again?
I would just refill the gear oil and check it in 5000 miles to see how bad it is. Moly mixed in will not really cause a problem.
....and do the breather mod that was already described. Moly is damn good stuff!
I need to do this mod. My front diff looked like this. It's on the list in the "BOOK OF MODS"...
When working correctly, the factory breather is a one-way valve, (allowing air out only, so sucks from the knuckles with each heat cycle) they often become blocked making it worse. When the pressure differential becomes high enough, some burps past the seals, usually this doesn't damage the seals. Converting to a free flowing breather solves this. The knuckles don't have breathers, but if the grease level is maintained at the proper level, there isn't much air space, so it's a non-issue.
I just put a tube of grease in each knuckle last night and i could have taken more, so it sounds like they just must have gotten a little low and drew in some air. Anyone have tips or must do's for cleaning out a clogged breather? i.e. is it the hose, the valve or the passage into the axle that typically becomes clogged? and if its the passageway, whats the best way to clear?
Take the breather hose and box off, toss in the bushes, get ~6' of 1/4" line, run it up by the brake booster, cap with a cheap filter, done.
I bought the hose and I can grab a filter, and get it done tonight. I will probably try and get the rear one while im at it. Whats the story with the T-Case and Trans breathers?
I haven't looked at this mod much but do you run the rear and t case all together, "T"ing them together as you go in to one filter up by the brake booster? Or run separate lines and filters for each one?
Here and another time you make sure to specify that the knuckles do not have breathers. This is true.
What if they had breathers? What if the were tied to the axle breather? There is a convenient port in the knuckle already... thoughts?
... Whats the story with the T-Case and Trans breathers?
They terminate on the dipstick tube and are free flowing, for most uses good enough. When we upgrade, use 3 separate lines; trans, transfer and CDL.
Separate lines and filters is best. If one unit gets contaminated, the fluid often foams and blows out the breather, if tied together can contaminate all of them.
It's just important to understand how it works, no matter what there will be some migration, but relatively slight, don't see it as a problem. To be totally perfect they would have breathers, but don't see how an effective one would be designed? The grease circulates, slings all around in the knuckle, would quickly plug up the system.
Thanks. That makes sense. I need to do this ASAP. I'm certain my breathers are plugged...
@Tools R Us that is a good point. The grease slinging around in the knuckle would most certainly plug up a breather if one were added in the knuckle. I hadn't thought about that when I posted my response earlier.
