Engine. Done
Well it has been a few months since I did any updating so here it goes...
I had a few days (5 total) to work on detailing and painting the engine, putting all new gaskets in and front/rear seals. As you can see from the photos below, the engine had 30 years of gunk and goo all over it. I had a little help getting it on a engine stand and then I hit it with about 4 cans of oven cleaner. I then used several wire brushes, picks, and razor blades to get all of the old gasket material off.
Some of you might say "Wow...five days" ...it seemed to take forever. I took every nut and bolt, air rail plug, engine mount bolt and media blasted them. I then painted all of them individually. I cleaned out the oil pan so well you could have ate out of it. Then the assembly process started. My biggest mistake was not getting the rear main seal in while it was on the stand and oil pan off. I couldn't get to it and ruined my seal trying to install it.
Also in the pics is the engine sitting back in the chassis. The next time I get 4 days to work I am lifting the engine back out and I have to attach the new rear cross member and supports and then one more coat of POR15 and then I am shooting it with Chassis Coat. Then everything will be torqued down to spec and engine placed back in for good.
I need to run my transfer case up to Steve in MN as I do not have time to go over it and get everything done. I have all my brake calipers, pads, brake lines to complete my chassy. I'm slowly seeing the light at the end of the tunnel.
Also you will see rebuilt warn hubs. I took them all apart, cleaned, painted and replaced with new seals. I polished the turn dial instead of painting it.
I couldn't have done all of this without everyone on this forum. I appreciate everyone here.
Mark
**Yes I know I have a broken bolt sticking out there. Just haven't gotten around to getting it out..
