- Joined
- Oct 24, 2014
- Threads
- 3
- Messages
- 43
First off, I really like my new Land Cruiser. I have wanted one of these rigs for a long time and I'm glad i finally pulled the trigger. However, I do have one small annoying issue.
The issue I am having is a buzzing/resonance I can feel in the steering wheel and gas pedal between roughly 1900 and 2100 rpm. I first noticed this the day i took delivery and now I can tell just by feel when I pass through this rev range. The buzz is not bad, but unexpected considering how smooth the drive line is otherwise.
I did some research and I have come up with some possibilities. It appears that back in '09 there was a TSB for a similar issue and the problem was linked to the transfer case. The fix was to replace the transfer case with an updated unit. Considering my Land Cruiser is a 2014 I have to assume that I have the updated transfer case so I'm hopeful my problem is not related to that TSB. The other possibility I found is exhaust drone. Apparently this is an issue with some 2014 Tundras as the exhaust was a changed for that truck in 2014. I haven't a clue if the Land Cruiser received a revised exhaust in 2014 like the Tundra, but I figured this could be the potential source of my problem.
Has anybody else here noticed this issue? If so, where you able to get it fixed? I'm hoping it is something minor as I just came out of a vehicle that had a problem which took forever to fix properly. I actually bought the Land Cruiser two days after picking up my truck that had been at the dealership for 30 days in a row getting fixed.
