Try two 5lb sledge hammers. Place one against the side of the pitman at the splined hole like a floating anvil and hit it hard with the other 180 degrees out. Do this a bunch of times. If you only have one hammer you can use anvil in place of the first hammer. You'll probably need someone to balance the box. The shaft is tapered so the idea is that a sharp blow straight on will compress the hole and force the arm to walk down the taper. It also helps break up any rust holding it on
I lay an 8-10lb sledge on the floor , position the box on some 4x4's so it's level and give it a good solid whack with a 3-5lb maul or hand drill opposite the sledge face - they usually fall off by themselves . If not , the puller comes out with some tension on the pitman and the Harris comes out . You cannot use propane toy torches for this kind of work , not nearly enough heat fast enough - it just soaks the joint and makes it worse . Banging on the puller really hard or using a pickle fork can destroy the box - that is a big no-no . Never had one beat me in over 30yrs yet ...
Sarge
I get a lot of people with that one - worked around a lot of very old guys growing up who taught me most of what I know , which results in using terms no longer recognized in this world . That's where I get the basics , like using paraffin to loosen parts under light heat ...
Sarge
..... You cannot use propane toy torches for this kind of work , not nearly enough heat fast enough .... ... Sarge
.... proper term is a hand drill - those short-handled big hammers were for hand drilling rock many moons ago in mines and quarries ................... Harris Steelworker torch comes out with a large cutting tip . ....................Sarge
Instead of destroying a p/s gearbox or mangling a $350 cross shaft, why not just slice through the pitman arm where it is stuck on the shaft with a cutoff wheel, clean up the splines, slap a new or used arm on it, and call it a day? You can find a good used arm here on Mud cheaper than buying another puller or fork.
